FRT Bearing Drivers side
Old Dec 21, 2011 | 1:50 PM
GM Fixer's Avatar
Default FRT Bearing Drivers side
The drivers side frt bearing is noisey AGAIN. New one installed at GM dealer at 111267km. Now truck has 224860km not impressed at GM right now. Truck is a 2004 Silverado ext. cab Z71 K1500 5.3L it will cost $409.14 MERRY FLIPPING CHRISTMAS
Old Dec 22, 2011 | 3:55 AM
96 Junk That Moves's Avatar
Front hub bearings have regular service intervals. If the proper service intervals have been done at the proscribed mileage then you have another service issue that is causing the bearing to fail. If the services were not done then no foul on the truck.
My 96 has 260k and still has the original front bearings due to a regular preventive maintainance schedule,,,just some thoughts.
Charlie
Old Dec 22, 2011 | 5:50 AM
Charlie
an 04 bearing is sealed from the factory and is non-servicable.
Old Dec 22, 2011 | 5:55 AM
was the replacement bearing AC/delco or OEM? Delco is no longer OEM for GM and they are junk. From the cost you quoted; sounds like a cheaper delco bearing.
Old Dec 23, 2011 | 3:39 AM
My bad...Both my early models have serviceable front bearings. Not up on the later model trucks.
Charlie
Old Dec 23, 2011 | 6:11 AM
BIGGG11CHEVY's Avatar
Like Tech2 said you deffinately want OEM bearings and any front end component really or youll just keep replacing them... The bearing is VERY easy to change though takes about 20 minutes. Just pop off the wheel and brakes, take off the axle nut, and its held in by 3 bolts on the back. You can also find dealer OEM parts about half price on Ebay...
Old Dec 24, 2011 | 7:17 AM
just talked to my parts guy...i was wrong...a/c is still gm oem but they have different lines. The bearing issues i've had were using the lower quality line.
Old Dec 26, 2011 | 6:24 PM
sct45's Avatar
I just replaced frt hubs on 02 silverado, used timken hubs, abs sensor was bad in one, had to use the sensor from the old hub, local guy wanted 270 for the timken hub and 130 to install, i got it on amazon for 115.,but was on my own when the abs started activating on dry roads.
anthony303
Dec 31, 2014 7:57 PM
GM Fixer
Sep 7, 2012 10:38 AM
Ron37388
Dec 14, 2011 9:48 AM
retsub
Nov 18, 2010 11:24 PM
