Fuel System probs
Old Sep 7, 2009 | 11:42 AM
rl1997's Avatar
Default Fuel System probs
I have a 1997 Chevy Silverado 1500 with a 5.7L v-8. it will not start. It has plenty of spark but is not getting fuel to the intake. The pump is pressuring up but I'm wondering if it is not enough,. Any Ideas?
Old Sep 7, 2009 | 11:49 AM
86C10's Avatar
check the fuel filter
Old Sep 7, 2009 | 11:59 AM
myotherchevyisablazer's Avatar
you could try repacing the fuel filter as stated above(if clogged that would do it)if not the fuel pump must have the right psi to work right..i had one in my blazer that i thought was good, it was pumping just not the right amount of pressure>>>
Old Sep 7, 2009 | 2:18 PM
rl1997's Avatar
Thanks, I have replaced the fuel filter with no new results. any idea how to check the psi from the fule pump?
Old Sep 7, 2009 | 2:41 PM
86C10's Avatar
hey pour some gas down the TB and see if it will start
Old Sep 7, 2009 | 2:57 PM
lukemoore646's Avatar
it may sound like its getting pressured up but the pumps can loose eficiency over time and not build enough pressure, there is a test port at the back of the engine on the fuel lines
Old Sep 7, 2009 | 3:04 PM
rl1997's Avatar
I found the test port. gas dribbles out when pushed. Should it spray out?
Old Sep 7, 2009 | 3:14 PM
86C10's Avatar
yes it should spray
vbob2
Aug 2, 2007 1:16 PM
acinider
May 23, 2007 8:16 PM
talkinggoat
Oct 23, 2006 7:02 PM
bjthebetsig
Aug 26, 2006 12:24 PM
