Last edit by: IB Advertising
- Chevrolet Silverado 2007-2013: Geneneral Information and Maintenance Schedule
Step by Step instructions for do-it-yourself repairs.
Future Mechanical Repairs?
A year ago (in 2012), I bought a 2007 Chevrolet Silverado 1500 LS (4.8L 2wd gas) with about 75,000 miles. It now has about 89,000 miles. Since I didnt know what maintenance had been performed prior to owning it, Ive a lot of regular and preventative maintenance in the last year. Its looking and running great! Ive caught up on all the maintenance and am now looking forward to the next year or two. My question is what mechanical parts would anyone guess or know might be coming up to replace, fix, etc? I have the suggested maintenance schedule from the owners manual and am performing those items. Im interested in trying to identify future mechanical hardware items to fix and am considering stock piling a couple of parts to have one hand when the time comes. Heres a list of parts that Ive thought of so far as well as a list of what Ive maintained/repaired.
Considering buying:
Starter
Alternator
Water Pump
Spark Plug Wires
Oxygen Sensors
Done so far:
Oil and filter changed to full synthetic, extended mileage.
Battery new, 3-year battery.
Alternator checked. Charging correctly.
Transmission Fluid / Filter / Gasket replaced / new.
Differential Fluid / Gasket replaced.
Power Steering Fluid replaced.
Brake Fluid bled / replaced.
Brake Pads new.
Brake Shoes new.
Spark plugs new.
Air Filter new.
Throttle body cleaned and performed relearn procedure for idle control.
MAS cleaned.
Belts replaced serpentine and AC belts.
Tensioner replaced AC belt tensioner.
Tire Pressure Sensors previous owner took them out. Replaced with new and performed relearn procedure.
Considering buying:
Starter
Alternator
Water Pump
Spark Plug Wires
Oxygen Sensors
Done so far:
Brake Pads new.
Brake Shoes new.
Spark plugs new.
Air Filter new.
MAS cleaned.
Nice comprehensive list
Might want to add to that list shocks / struts
Inspect motor and transmission mounts.
inspect/lube or replace if dried out , sway bar bushings...
inspect/lube u-joints
at 5 years old, I would replace the hoses and coolant...
consider cleaned and lubricating all door seals with silicon lubricant
Lube all hinges and lock/latch mechanisms with lithium grease..
I could go on....
I could go on....
Please do go on...
I didn't list all I that I did, but I've:
- Replaced the sway bar bushings (they were not even there anymore)
- Replaced the lower coolant line (top one looks good)
- I'm replacing a three-way hose attached to the coolant reservoir (minor leak)
- conditioned all door seals with 3M pure silicone paste lubricant
- lubed all hinges / locks with lithium or powdered graphite
- among other things
I'll have to figure out your suggestions about inspecting/lube U-joints, shocks / struts, motor / trans mounts (thanks for the suggestions). What do you think about the list of mechanical parts I'm considering buying? I'm trying to figure out what could wear out next and have some time so shop for replacement equipment.
I wouldn't suggest purchasing and "stocking" them until needed, as that can be an expensive venture if for what ever reason you get a defective part and by the time you need it, the warranty has expired... and it is plausible that you may never need them....
Unless you are located in the sticks, most on-line retailers (i.e. Amazon) can have the parts in your hands in 24 hrs....
I have gone thru Amazon and located a lot of the parts for my truck and put them in my cart and "saved for later" It gives me instant access to current prices and part numbers
same goes for Rock Auto
For planned maintenance, you can't beat having the parts delivered to your door...
Here are just a few examples:
same goes for Rock AutoFor planned maintenance, you can't beat having the parts delivered to your door...
Ok, Grumpy. Some of us continue to learn throughout life. I am one of those. Autos have never been a concern of mine. I've discovered that they are extremely interesting in every aspect. If I were related to your wife, I certainly would not want to hang out with you. Bye.
I think retired wrench's comment was meant to be interpreted as scarcasum, and not a jib at you...
as I can relate to the worrying wife..they want to make sure they have every base covered
Thanks for the ideas of things to check.
I am more interested in learning more about the mechanical systems, parts, or whatever, not worrying like retired wrench above is suggesting. I've taken an ok running used truck back to the point of running practically like new. I'm amazed at how well it's running. Now that I've brought it to this point, it's become a pleasant hobby to learn more and more. After owning a new, Ford King Ranch for a few years plagued with a few significant problems (mostly covered by warranty), it's great to have a Chevrolet. Personally, I find them relatively easy to work on and enjoyable to own.
I've learned a lot from this forum, repair manuals, manufacturers, various internet sites, knowledgeable friends, and, yes, a couple of retired mechanic neighbors.
