Last edit by: IB Advertising
Browse all: Engine and Powertrian
- Chevrolet Silverado 1999-2006 GMT800 How to Replace A/C Belt Tensioner
grinding noise with defrost or A/C
91 1500. grinding noise coming from somewhere in the front, cant tell if engine compartment or inside cab when activating either Defrost or A/C. Anyone know what's going on? At first I thought it was the compressor until I realized it does it with defrost too. Which makes me wonder if there's "two" blower motors in this truck?
You do not have two blower motors. In defrost mode your A/C compressor does run. Most likely culprit of the noise is the a/c clutch. You may be lucky and just have to replace the clutch assembly, but most likely the compressor also.
The a/c belt tensioners go bad also and are a common problem. remove the a/c belt and see if the tensioner is seized or the tensioner pulley is worn. Spin the A/C compressor pulley while the belt is off to see if it is has play or has bad bearings.
hondachevy500
February 3rd, 2009 6:57 PM
mcculleb
December 8th, 2007 2:01 PM
