Old Jul 24, 2015, 4:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
grinding noise with defrost or A/C
Old Dec 21, 2012 | 6:25 PM
80skeys's Avatar
Default grinding noise with defrost or A/C
91 1500. grinding noise coming from somewhere in the front, cant tell if engine compartment or inside cab when activating either Defrost or A/C. Anyone know what's going on? At first I thought it was the compressor until I realized it does it with defrost too. Which makes me wonder if there's "two" blower motors in this truck?
Old Dec 22, 2012 | 3:56 PM
jay-rod's Avatar
Had the same thing happen. I was told it was the beginning of my compressor starting to go bad. If you find out let me know.
Old Dec 22, 2012 | 10:42 PM
jwruss's Avatar
You do not have two blower motors. In defrost mode your A/C compressor does run. Most likely culprit of the noise is the a/c clutch. You may be lucky and just have to replace the clutch assembly, but most likely the compressor also.
Old Dec 23, 2012 | 9:09 AM
The a/c belt tensioners go bad also and are a common problem. remove the a/c belt and see if the tensioner is seized or the tensioner pulley is worn. Spin the A/C compressor pulley while the belt is off to see if it is has play or has bad bearings.
Old Mar 22, 2013 | 8:21 AM
80skeys's Avatar
Hey, I finally got around to replacing the A/C tensioner and tensioner pulley, and that fixed it.
Jezah
Sonic (Aveo)
Aug 21, 2011 11:33 PM
Znelwonders
Feb 18, 2009 7:53 PM
hondachevy500
Feb 3, 2009 6:57 PM
TrkMas3122
Mar 11, 2008 3:43 PM
mcculleb
Dec 8, 2007 2:01 PM
