grinds going into 4 low
Old Apr 28, 2011 | 5:20 PM
zbkeebler's Avatar
Default grinds going into 4 low
i have a 94 k1500 with a 5.7 and 4 hi works fine but when i try to put it in 4 lo it makes a grinding sound. when the truck is off i tried putting it in and it locked the front driveshaft so i know it can engage but what causes the grinding noise?
Old Apr 28, 2011 | 6:53 PM
Mille Racer 69's Avatar
Sometimes it'll do that if the road is not perfectly flat.
mine has done it a few times.
I would just turn the truck off and put it into 4 then vice versa for 2wd.
So I am confused though, you say you turned it off, switched it into 4 and
all the wheels were locked up?
is this on dirt or pavement?
don't use 4 low on pavement.
Old May 2, 2011 | 2:18 PM
zbkeebler's Avatar
I bought it a few months ago and I was just checkin to see if everything worked. I definitely know not to use 4 wheel drive on pavement..
Old May 2, 2011 | 9:37 PM
well, 4 low on pavement. I use 4 hi if it is snowing and required.
Old May 2, 2011 | 9:49 PM
monkey's Avatar
I saw on you tube,a guy with a supercharger 4x4 chevy late model smoked all 4 tires,so much for the transfer case!
DSHACK13
Colorado
Mar 1, 2014 5:22 PM
caddieb
May 15, 2011 5:32 PM
tom5170
Nov 30, 2010 11:41 PM
bcacali24
Jul 18, 2007 10:33 AM
chasM
Oct 8, 2006 3:03 PM
