Having hard time starting truck
Old Jul 31, 2011 | 1:27 AM
pauljd's Avatar
Default Having hard time starting truck
I recently just bought a 97 chevy ext cab 4x4 with a 5.7 vortect with 125k miles and was running great for a week and now when i go to turn the key to start it turns over but just not wanting to start,I put whole new spark plugs in and changed the fuel filter ( which was dirty inside ) and still doing the same thing.Now people are telling me that it could be a fuel pump so I looked online and see how to tell if the pump is workn and they said you will hear a buzzing sound for a second (which I do from the pump) when u turn the key and the other ways are to open the filler cap and listen for the pump which i hear as well.fuses/relays look good also.So im thinking its the starter/fuel pump going out on me.when I bought the truck it did came with a autostart key remote to start the truck from a distance which has problems startn so thinkn that could be the cause of it? any help would be greatly appreciated!
Old Jul 31, 2011 | 8:51 AM
shamrock246's Avatar
whats the fuel pressure key on engine off should be 60-66psi ?whats the pressure when running?does it hold the pressure for a awhile or does it bleed off right away
Sean
97 4x4 burb
ChevyBoy17
Jan 15, 2013 10:05 PM
SlimDoggy
Aug 23, 2012 1:05 PM
talamant3z
Sep 26, 2010 7:48 PM
WhiteZ28
Camaro
Mar 18, 2010 10:09 PM
dirt_cavi_54j
Jan 23, 2008 12:36 AM
