Heat stuck on
Old May 21, 2011 | 7:19 PM
jtprice's Avatar
Default Heat stuck on
i have a 2000 Chevy Silverado 1500. having an issue that my air is constantly on HOT! thankfully i can shut off so i dont have hot air blowing @ all times, but regardless if i turn the a/c on, turn the fan on, or mess with the hot/cold gauge it just continues to blow supper hot air. the only way to stop is to turn the fan off. Any ideas on what might be going on?
Old May 22, 2011 | 12:37 AM
zm1040's Avatar
Maybe you are in need of a recharge?
Not sure but I'd go to a place that will do a free check to see if it needs freon.
Old May 22, 2011 | 10:28 AM
OLD WRENCH's Avatar
Sounds like a "mode door" actuator has gone bad. The mode door directs the incomming air either past the heater core or the AC evaporator. The control itself can also go bad,thus not telling the actuator to act.
Old May 23, 2011 | 8:54 PM
jtprice's Avatar
thanks for the note. another wrinkle to the story is that i got back in the truck yesterday and everything works just fine. would this lead you to believe it might be the control for the mode actuator?
Old May 24, 2011 | 10:54 AM
OLD WRENCH's Avatar
Yes. The actuators dont come and go.
BigblackHo3
Apr 5, 2013 8:54 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
