Help anyone?
Old September 4th, 2012 | 9:31 PM
LS Silverado's Avatar
Default Help anyone?
Ok so I have an engine tick only on the right side of the.. does it when its cold and when hot.... Mechanics tell me its the pistons some tell me its the lifters.. Any help?
Old September 4th, 2012 | 11:13 PM
jesse06's Avatar
could be either without taking the head off to check the valves for abnormal wear marks or built up carbon. usually a tick is a valve/lifter. more of a knock is a piston
Old September 5th, 2012 | 12:47 AM
I can hear it when i accelerate if that makes a differance
Old September 7th, 2012 | 9:54 AM
Official GM Rep
Good morning LS Silverado,
You mentioned that you've had some mechanics take a look - were these with one of our GM dealership? If so, and if you would like for us to look into this further with them, please send us more information privately, including your name and contact information and the last 8 digits of your VIN.
Sarah (Assisting Louis), Chevrolet Customer Service
Old September 7th, 2012 | 11:39 AM
kevinkpk's Avatar
Probably a lifter if it never stops. It could be piston slap, that usually goes away.
Old September 7th, 2012 | 1:11 PM
Allan In NE's Avatar
Check for exhaust leaks on that right side. Will sound just like a "tick".
Allan
Old September 7th, 2012 | 4:33 PM
I know ive herd piston slap goes away once the engine is hot... Mine can hot or cold itll do it.. Ill check for An exhaust leak tomorrow morning
Old September 7th, 2012 | 10:40 PM
ukrkoz's Avatar
run can of Seafoam in crankcase for about 1000 miles, then change oil. If truck is not taking oil, replace with at least semi synthetic. See what happens.
I run on Amsoil and do my oil changes when tsa-tsa becomes heard. Which is around 12 000 miles or so.
k_grantham10791
10
January 11th, 2014 1:18 PM
Dirtiest Hoe I know
December 1st, 2011 7:45 PM
boxtones
July 29th, 2008 12:35 PM
96w/17sMonte
October 23rd, 2007 7:18 AM
fryboy3k
October 9th, 2006 7:06 PM
Quick Reply: Help anyone?
