Help identifing a rear axle
Old May 25, 2011 | 9:43 PM
cajunduckhunter's Avatar
Default Help identifing a rear axle
I have a truck with a 12 bolt . Near as I can figure with a TH350 at 55mph I am only turning around 16-1700 RPM with 28" (275-60-15) tires which makes the gears very close to 2.56
Here are the numbers I found on the axle. Can someone tell anything from these numbers. Diff. is single rib, numbers on cast are E8-81, NF3896838, GM57 and a stamped number on top of passenger side tube HA 05 22W
When truck is on jack and I turn one wheel the other turns the opposite way but it will lay 2 tire tracks if you gas it at start. IS it possibly Limited slip?
Old May 26, 2011 | 11:50 AM
usmarine0905's Avatar
open your glove box, there is a sticker in there that will give you the RPO code for the rear axle..... it should be a "G" code if I am correct, exp G80... then google that code and you will know your axle ratio...... good luck
Old May 26, 2011 | 12:03 PM
Default Reply
This truck is 45 years old and probably doesn't have the original axle anyway much less the original glove box.
Old May 27, 2011 | 5:11 AM
ok, sorry you did not state that in your question....... im sure someone out there will be able to help.......
Old May 27, 2011 | 8:33 AM
OLD WRENCH's Avatar
Go to "FullSizeChev" those guys are always messing around with stuff like this.
Old May 28, 2011 | 7:08 AM
Default Reply
Thanks USMARINE
bando221
Jun 30, 2013 6:08 AM
bbolin00
Mar 18, 2010 9:18 PM
dcathey
Sep 3, 2007 7:21 AM
blackwhiskeyblaze
May 12, 2007 11:38 AM
flstfse
Sep 30, 2006 7:28 PM
