Help me out!
Old Aug 18, 2010 | 4:57 PM
oght's Avatar
Angry Help me out!
Alright so Ive had my Silverado 1500 for about a year now. Its a 2000 with the V-6 Vortec with an auto tranny. Something isnt right with either the u joints or the transmission. Its fine just putting around town but if I drive it a good 30 miles It starts kicking hard into second. Ive been told its the u joint but im just not convince. Its a weird kick i cant tell exactly whats causing it. Can anyone help me out?
Old Aug 18, 2010 | 5:12 PM
replace the U-joints after 10yrs there probably ready....
Old Aug 19, 2010 | 10:27 AM
therewolf's Avatar
Hi oght,
Welcome to the Chevy Forums.
Let's eliminate the easy stuff first. Check the transmission fluid, and make sure you're not running low. Because that will make for an awful 1-2 shift.
Old Aug 19, 2010 | 2:38 PM
oght's Avatar
Thanks for the info i had assumed it was the u joints i know its not the tranny fluid and it sure as hell isnt the tranny. I just needed some confirmation. Thanks again.
Old Aug 19, 2010 | 11:18 PM
s34n's Avatar
might need to replace the shift solenoid.
Old Aug 20, 2010 | 8:03 AM
Dopeoperator's Avatar
when is it better to check the transmission fluid before during or after use. At my job we are required to check the tranny fluid during use just put it in park and check it after the equipment has been run for a while. Our maintenance guys say its cause the tranny fluid expands when heated and that gives you the accurate measure. This sound right?
Old Aug 20, 2010 | 11:33 AM
2wd-K5's Avatar
yea after it has been running is the best time to check
Old Aug 20, 2010 | 6:08 PM
s34n's Avatar
or check it while the engine is running and at operating temp.
Old Aug 21, 2010 | 11:24 AM
2wd-K5's Avatar
yea sorry, while running lol
Old Aug 22, 2010 | 11:41 AM
oght's Avatar
Question
Im actually pretty concerned cause something tells me its the solenoid. Im no mechanic i can do brakes a joints and regular maintenance but ive never messed with the transmission or the solenoid. How much would it cost to get the damn thing fixed?
