help p0300
Old Feb 17, 2013 | 2:45 PM
Sherwoood's Avatar
Default help p0300
i have a 03 chevy 2500hd with the 6.0. my check engine light will come on and flash. it does it between 2000 and 2500 rpms. It has a fresh tune up, 171,000 miles.
Old Feb 17, 2013 | 2:57 PM
kevinkpk's Avatar
That is random misfire. Did it do this before the tune up?
Old Feb 17, 2013 | 5:44 PM
Sherwoood's Avatar
yes the code was there before. this was the reason why i did the tune up wasnt sure when the last time it was done. it doesnt see to run rough or anything and it seems to happen more when its cold.
Old Feb 17, 2013 | 8:14 PM
country_09's Avatar
What all was done in the tune up?
Old Feb 18, 2013 | 11:56 AM
Sherwoood's Avatar
Plugs and air filter the wires still looked good
Old Feb 18, 2013 | 2:40 PM
country_09's Avatar
They can look good, but can be deceiving at the same time, also check out the mass air flow sensor and o2 sensors and cats. All can cause the po300. If its flashin it's detecting a very bad misfire
Old Feb 18, 2013 | 2:52 PM
kevinkpk's Avatar
What does it idle rpm, when cold? Do you have it after warmed up?
Old Feb 18, 2013 | 7:55 PM
Sherwoood's Avatar
[QUOTE=kevinkpk;241060]What does it idle rpm, when cold? Do you have it after warmed up?[/QUOTE
Im not sure on the rpms at idle when cold. It doesn't seem to flash when warmed up. If the engine light disnt flash i would not know there was a problem
Ecssound
Jul 9, 2012 9:57 PM
TURBOPOWERED68
Jan 27, 2012 1:04 PM
Ecssound
Jan 23, 2012 5:19 PM
tboz
May 21, 2010 9:08 PM
tat2dup81
Sep 28, 2009 6:16 PM
