Help selecting crate engine
Old Nov 5, 2011 | 11:35 PM
bosshog55's Avatar
Default Help selecting crate engine
I have never had to get an engine replaced on my 98 MC Z71. I have a few questions on the whole process, I live in Texas and when i replace the engine does the transmission need to be replaced at the same time? The original engine and transmission have 190k miles i plan to replace it in January if it doesn't crash before hand. What is a good brand to get?? What is the typical cost to replace everything. Local mechanic quoted me 4k to replace engine and get new motor but I have heard its been done cheaper. any help would be great
Old Nov 6, 2011 | 7:34 AM
recondrill's Avatar
I assmume you're looking for a new motor because your is broke past repair? if the block is not cracked, most motors can be easily rebuild for a fractio of a new one. (just food for thought). You don't have to replace the tranny, but have it rebuilt. New seals and prehaps new bearings will prevent more time in the shop than the road/trails.
Brand name is not super important, what you have to consider is what you expect your new motor to do for you...daily driver, towing, off roading...depending on your use can help steer you to the right choice.
Another option is get a new motor from a newer model GM truck at a salvage yard. Many have a warranty you can buy, just incase the enging is crap. This will save you $$$$.
Old Nov 6, 2011 | 11:18 AM
Mille Racer 69's Avatar
Get an LS1 engine.
It will mount straight to your 4L60E transmission.
You will have to get new engine mounts, headers and an ecu,
But you would have 1 awesome truck and bragging rights.
You can go to LS1truck.com for information
Old Nov 7, 2011 | 8:07 PM
Kahoutek1973's Avatar
If you are just looking to replace with the same performance and don't want anything crazy try Jasper.I fyour trans has that many miles on it.I would replace it as well.
Old Nov 7, 2011 | 8:15 PM
bosshog55's Avatar
The truck is still running but has a defiant knock. I assume it could be repaired, i would definitely like to rebuild it if possible and save some $$ but the thought of having a pretty sweet ride is tempting. Next question i hear a lot of people replace the rear end as well during all of this, is that recommended?
Old Nov 8, 2011 | 5:14 PM
changing the rear isn't something I would worry about unless you're having problems with it.I would personaly never buy a crate motor,but Ive built my share,and it's always rewarding to see something you put together come to life.LOL.But if you don't have the know how then leave it to the experts.
Jmann
Nov 7, 2014 10:26 AM
Dale002
Oct 30, 2012 11:43 AM
jeepmkcomin
Apr 9, 2009 11:53 PM
superk10
Jan 21, 2008 7:43 AM
HouseOfWheels
Dec 15, 2007 5:55 PM
