Horse power and torque specs for 88 5.7
Old Oct 2, 2010 | 5:04 PM
1988scotdale's Avatar
Default Horse power and torque specs for 88 5.7
Hi All, I want to add posi to my truck, and in addition change the gear ratio of my 2wd. I need to find the rpm's for the horsepower and torque ratings for my 5.7. Thanks for any help.
Old Oct 2, 2010 | 5:09 PM
Overtime's Avatar
Horse power for a 88 chevy 350...wait for it... 190 to 210 stock.. That all I know off the top of my head but you could google it.
Old Oct 2, 2010 | 6:26 PM
2wd-K5's Avatar
yup 210
Old Oct 2, 2010 | 6:28 PM
Overtime's Avatar
And that is on a very good day, with all the planets aligned.
Old Oct 3, 2010 | 9:54 AM
Thanks everyone. I may have asked a poorly worded question. I need to know the horsepower and torque ratings at what rpm for each. 210 hp @ ?rpm. ft.lbs @ ?rpm.
I am going to put a posi unit in my truck because the wheel spin on wet pavement. If I knew the torque and HP rpm ranges....I may change from a 3.42 to maybe a 2.73 rear gear while it's apart.
Old Oct 3, 2010 | 7:19 PM
wellmax's Avatar
I have a 2500 series, 2000 model with 350 engine.
it has 255 hp and 330 pds of torque.
I have the 3.73 differential and it will pull a fair load, I believe its rated for 7100 lbs.
If you go to a 2.73 ratio with the older 350 engine you will not have much power.
in a old truck, in order to pull you need torque, that is why so many who can afford it are going to the diesel engines.
I have the same problem, only one wheel on my differential will pull at one time and if someone in the next county spits on the road I will get stuck.
Old Oct 5, 2010 | 1:45 AM
Thanks all, I found the info in 1988 Chilton shop manual at a friend's auto repair garage.
jjmoore
Apr 27, 2010 1:25 AM
HNeto
Camaro
Jul 14, 2009 4:59 PM
petrou
Apr 3, 2008 7:36 PM
kfc6936
Nov 16, 2007 9:51 AM
y13supio
May 28, 2006 5:38 PM
