I need help!
Old Jan 20, 2011 | 7:58 AM
WilliamFlakes's Avatar
Default I need help!
I have a 88 Silverado, I was headed to work & I needed to charge my phone, went to plug it into the lighter & all of a sudden my dash lights & parking lights go off. 1st inspection of the fuse block, I seen the parking light fuse was blown, I go to put another 1 n & before I can get it in all the way, 1 side of the fuse inlet is sparkin...is my fuse block bad or maybe just a short under the dash? Please Help!
Old Jan 21, 2011 | 7:37 AM
ExcessiveEgo's Avatar
there is either a short in your 12v outlet, or your phone charger is bad
the reason it sparked when you went to put the fuse in is the same reason your battery cables will occasionally spark when you hook them back up, if something is trying to draw current, the current will jump over a gap...... you left the lights on and/or the charger plugged in, didnt you...
be_Martinezr
Oct 6, 2014 10:19 AM
1stTahoe
Apr 19, 2012 9:44 PM
badabingman
Mar 4, 2009 8:26 PM
