Old Aug 10, 2015, 1:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
I WANT fog lights on my 2006 LS Crew cab
Old Sep 11, 2012 | 2:47 AM
Christopher Krumholt's Avatar
Wink I WANT fog lights on my 2006 LS Crew cab
I want fog lights on my truck is it possible? I have a 06 ls crew cab it dont have them..... Cant find much about anyone doing it before
Old Sep 11, 2012 | 5:34 AM
grumpychevy's Avatar
It's easy. Buy fogs off of eBay-factory replacements. Go to advance auto and buy a fog light wiring harness with relay. Go to autozone and buy a small illuminated round toggle switch-to mount in factory location. Either cut the holes in the factory valance or purchase a new lower valance. Follow instructions in wiring kit and drill hole for switch. Total cost minus a new valance is about $100.
Old Sep 12, 2012 | 3:32 AM
I want the HID to match my headlights. So I can I but a SS valance that will fit? I did not know it was called that or Rey even had a light kit. Thank u
Old Sep 12, 2012 | 9:12 PM
fastback4's Avatar
Grumpychevy is right on the money. I autozoned my fog/running/hid kit for right at $100.00
I have a 07 1500 4 door
Old Sep 13, 2012 | 3:40 AM
Awesome. Im going to try that this weekend. I notice i have a fog light button inside to turn them on and off. thanks for the responces.
Old Sep 13, 2012 | 5:27 AM
Double check that switch. If your truck didn't come from the factory with fogs, then it will not have the switch for them. What you see is more than likely the cargo light swith.
Old Sep 13, 2012 | 10:42 AM
country_09's Avatar
^ exactly. If it has a switch that's really fog lights, then it should be wired for it. All you'll need is the lenses and bulbs for it to work
Old Sep 14, 2012 | 3:32 AM
Thanks guys good looking out
Old Sep 14, 2012 | 7:14 AM
MDTAHOE's Avatar
Professional Mechanic
You can buy a factory add on kit from the dealer for around $250. It comes with everything, switch, wiring harness (looks like factory),lights and instructions. The fuse box usually is already pre- wired. When installed it will look like it came from the factory with fog lights.
Old Sep 23, 2012 | 6:57 AM
Does this come with the vallance also? I found a valance on carstuff.com they have it with 4 cutouts for 140 not to bad. Glad I found all this or I would not have known were to start looking.
