I'am I Missing Something? (K&N)
Old November 27th, 2007 | 5:34 PM
Bolander's Avatar
Default I'am I Missing Something? (K&N)
[hr]Looking at K&N's air intake performance kit for my '97 5.0 Silverado, I can't see, other then K&N's
filter, adding any more horsepower or torque then the stock system! The air flow looks to be fine.
If anything what about just leaving the cover off the stock filter housing?
Any comments?
Old November 28th, 2007 | 5:00 AM
03chevyrustbucket's Avatar
Default RE: I'am I Missing Something? (K&N)
I think the only thing you get is more noise and a air filter you can wash and re-use.
Old November 28th, 2007 | 8:07 AM
jcbst12's Avatar
It just smooths out the flow of air vs. the stock set-up. There is about 100 different uneven surfaces in the stock set up that create turbulent airflow and at high rmps prevents good (even) airflow to the engine. It does help a little with Hp and a good deal with throttle response over using just a high-flow filter. The best setup for the money is just buying an intake tube and a high-flow filter. Same gains, less bs. Airaid sells just a tube.
Old November 28th, 2007 | 9:44 AM
Bolander's Avatar
[hr]Jcbst12... I looked into Airaid, your right! Less money and same results (I would imagine).
Old November 29th, 2007 | 9:09 PM
IAfarmer's Avatar
I wouldn't waste my money. These trucks perform well stock, and unless you are changing anything else, keep it stock.
For it to matter you need: headers, catback exhaust, better head flow, more fuel.
Old December 2nd, 2007 | 6:48 PM
johnboy's Avatar
Can you change the chip
nehuge
September 18th, 2012 11:22 AM
weissmand
July 26th, 2010 11:44 AM
hrdkrtazz
18
June 28th, 2010 11:07 AM
mchgnmike
April 23rd, 2009 11:17 PM
silverado01ls
March 20th, 2007 6:23 AM
Quick Reply: I'am I Missing Something? (K&N)
