I'am I Missing Something? (K&N)
Old Nov 27, 2007 | 5:34 PM
Bolander's Avatar
Default I'am I Missing Something? (K&N)
[hr]Looking at K&N's air intake performance kit for my '97 5.0 Silverado, I can't see, other then K&N's
filter, adding any more horsepower or torque then the stock system! The air flow looks to be fine.
If anything what about just leaving the cover off the stock filter housing?
Any comments?
Old Nov 28, 2007 | 5:00 AM
03chevyrustbucket's Avatar
Default RE: I'am I Missing Something? (K&N)
I think the only thing you get is more noise and a air filter you can wash and re-use.
Old Nov 28, 2007 | 8:07 AM
jcbst12's Avatar
It just smooths out the flow of air vs. the stock set-up. There is about 100 different uneven surfaces in the stock set up that create turbulent airflow and at high rmps prevents good (even) airflow to the engine. It does help a little with Hp and a good deal with throttle response over using just a high-flow filter. The best setup for the money is just buying an intake tube and a high-flow filter. Same gains, less bs. Airaid sells just a tube.
Old Nov 28, 2007 | 9:44 AM
Bolander's Avatar
[hr]Jcbst12... I looked into Airaid, your right! Less money and same results (I would imagine).
Old Nov 29, 2007 | 9:09 PM
IAfarmer's Avatar
I wouldn't waste my money. These trucks perform well stock, and unless you are changing anything else, keep it stock.
For it to matter you need: headers, catback exhaust, better head flow, more fuel.
Old Dec 2, 2007 | 6:48 PM
johnboy's Avatar
Can you change the chip
weissmand
Jul 26, 2010 11:44 AM
hrdkrtazz
18
Jun 28, 2010 11:07 AM
mchgnmike
Apr 23, 2009 11:17 PM
silverado01ls
Mar 20, 2007 6:23 AM
