Issue after swap.
Issue after swap.
Just swapped engines/trannies in my truck. Now that I have things running, it is acting funny. It starts fine, and runs fine for approx. 20 seconds, then the idle will get rough. RPMs stay about the same, but it starts to shake noticeably. Not bad enough to kill it, but it's not pleasant. If I drive it, it will drive great for about a city block's length, then it will loose alot of power. I will have to give it about 3/4 throttle to drive around the block. It is shifting hard aswell. If I kill the engine, or stop and idle for a minute, it acts normal again, but only for that city block's length. Engine temp doesn't seem to make any difference. Only code being thrown is Random Misfire Detected...
Things new: Distributor, cap, rotor, wires, plugs, and basically every gasket short of HGs.
Things used from my old engine: All accessories except PS, crank pulley/balancer(old engine's was broken), crank sensor(old engine's was chewed up, causing no spark), fuel spider(just used this because it was newer), ignition coil(switched it over when troubleshooting the no-spark condition, since I knew mine was good).
It's a 96 4.3 Vortec.
So the misfiring cylinders are definitely getting fuel, but perhaps not enough to fire? Fuel filter is pretty new and I used the fuel spider out of the old engine, since it was newer and had been recently professionally cleaned. But a crimped line is definitely a possibility, I will look for that tomorrow. Thanks.
WSPrebs
May 23rd, 2012 3:50 PM
Why does my 2000 Chevy Tracker with 20 engine die after it gets hot but restarts OK after cooling fo
vixendrumr
November 8th, 2010 2:42 PM
