Its been a good truck
Old Aug 1, 2009 | 2:19 AM
Ynot7711's Avatar
Exclamation Its been a good truck
1998 silverado just put 1 new head on the right side , runs and misses bad at low idle but at a high idle slight miss , but when at and idling it doesn`t fire on 1,3,5,7 just found out yester day that it is gettig fuel and not firing on those four cylinders , yes the vale lash is good , wires and cap ohm out fine , crank sen and cam senoir test out good , i also need to check the coil driver and if that didn`t work i dont thank it would fire lol ,i also thank that so who some wy and is posible the pcm just could of gone bad , but i can read the all of the programs in the pcm
Old Aug 1, 2009 | 2:16 PM
wffokker's Avatar
You are sure your cap is good right?? I have had to replace mine numerous times, they short out due to bad design,
Old Aug 1, 2009 | 7:58 PM
suzuki-guy's Avatar
Are you sure your timing is right? Did you adjust the valves right?
Old Aug 2, 2009 | 6:11 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I think Zuk is right, sounds like you have little or no compression on that side, no compression no fire.
Old Aug 4, 2009 | 3:08 AM
Ynot7711's Avatar
thanks guy for your help , i still cant figure it out tho i would like to let you guys know that i had the heads checked . and the right one was bad and the left ok , so it has two new head gaskets on it and the compression test was good too,checked all the sensoirs and plugs and terminals on problems with that . and still runs on the right bank .
Old Aug 4, 2009 | 3:52 AM
suzuki-guy's Avatar
How did you adjust the valves?
Old Aug 4, 2009 | 12:12 PM
Ynot7711's Avatar
in the correct matter lol , i got it right i know i do , im ase certified in gm ford chyrsler toyota ex.
hokis
Jan 17, 2014 9:02 AM
Chevy_Joe
Feb 20, 2012 11:34 PM
kinger
Dec 26, 2009 7:35 AM
Sloancanfield
Mar 3, 2009 8:31 PM
