Just The Oil Pump?
I am having low oil pressure issues. Have done an oil change to check if it was just a collapsed filter as well as putting in a heavier oil in attempts to improve the oil pressure. Also have ruled out the sending unit.
Is this likely to be just an oil pump problem? Or is it likely to be a bigger problem like bearings?
Is it a difficult process to remove the oil pan on a 2004 Silverado? Can you just remove the oil pan?
Casual Mechanic
June 22nd, 2015 11:20 AM
97Chev1500
September 21st, 2010 12:56 AM
gumbute
December 1st, 2009 10:21 PM
larry_chip
April 24th, 2007 11:46 AM
