k 1500 tranny
so my girl friends brother bought a k1500 for a few hundred bucks good deal right???? not! so the tranny goes and we are in the search for a new tranny. the truck is a 4x4 and has a column shifter. what kind of tranny am i looking for and what would be a decent price on this tranny??? thank you every one
what year is the truck? and dont take a blown tranny in the worst thing possible, ive had 4 trannys go on my truck so far and im yanking out this one this weekend to rebuild it myself
He already bought it and the trans went its a 95
we found a trans from a 92 but will they swap ? its a manual but I have the equipment to take the old one out and punch a hole in the floor .... not really looking forward to it
IF it will work you'll need a clutch..everthing to hook that up(slave cylinder,pedle ect) and possibily a different transfer case if its forwheel drive(im not sure on this one)
also it will probably matter if it the trans if 4x4 or 2wheeldrive
It's was a 4x4 auto before I'm hoping to drop a 4x4 manual in I have the clutch and all that I grabbed the wiring harness too cause I'm not sure if the hook UPS are the same
it will work, you will need the pedal set-up from the donor truck and buy a new clutch, you will also need the flywheel from the donor truck. wiring harness isnt a big deal all u need is the 1 wire for the reverse lights, also make sure you take out the gears from the speedo cabl out of the original transfercase and put iti into the new one
donbrearley
June 26th, 2013 10:26 AM
DeHartShadow
March 28th, 2010 10:10 PM
89silverado283
February 16th, 2010 8:50 AM
revamped
August 24th, 2008 10:48 PM
revamped
January 23rd, 2008 4:03 PM
