Key wont turn past accessory. Physically won't crank via key turn.
I've got a 1991 Chevy Silverado Manual transmission that has run with zero issues until all of the sudden I go out to start it and physically cant turn the key far enough to actually crank the engine.
The ignition switch/tumbler should all be fine as i can turn the key into accessory mode, get radio, lights, unlocked steering wheel etc. but past that i get about 1/4" turn before it becomes un-turnable.
I don't believe this to be a problem with the ignition switch or the key (i tried 2 separate ones) as the problem is happening after all the important unlocking in the cylinder has happened.
Any help would be greatly appreciated as i don't want to throw money at the problem without knowing whats going on.
Thanks!
Thanks!
eromore189
March 30th, 2014 12:12 PM
advcomps
September 18th, 2013 10:22 AM
Livermoron
February 19th, 2012 2:43 PM
