Key wont turn past accessory. Physically won't crank via key turn.
Old Sep 3, 2013 | 3:46 PM
G T Igofast's Avatar
Default Key wont turn past accessory. Physically won't crank via key turn.
I've got a 1991 Chevy Silverado Manual transmission that has run with zero issues until all of the sudden I go out to start it and physically cant turn the key far enough to actually crank the engine.
The ignition switch/tumbler should all be fine as i can turn the key into accessory mode, get radio, lights, unlocked steering wheel etc. but past that i get about 1/4" turn before it becomes un-turnable.
I don't believe this to be a problem with the ignition switch or the key (i tried 2 separate ones) as the problem is happening after all the important unlocking in the cylinder has happened.
Any help would be greatly appreciated as i don't want to throw money at the problem without knowing whats going on.
Thanks!
eromore189
Mar 30, 2014 12:12 PM
advcomps
Sep 18, 2013 10:22 AM
Livermoron
Feb 19, 2012 2:43 PM
91camaro350
Camaro
20
May 5, 2010 8:14 PM
uproar1
Apr 21, 2010 5:05 AM
