Key wont work?
Old Nov 21, 2010 | 7:33 PM
Countryboy95's Avatar
Question Key wont work?
My 1989 Cheyenne 2500 was running just fine a few months back then i went out to start it one day and the key just didnt work i tried everything i could think of. Now i am thinking i need to do one of three things.
1.Just replace the tumbler
2.Wire it up on a switch and starter button
or jam a screw drive in it tell it twists it just my old truck that i dont really do anyting with anymore but i need it moved so the plows dont hit it. anyideas on what i should do or can do to get it moved with the least money
Old Nov 21, 2010 | 7:55 PM
MDTAHOE's Avatar
Professional Mechanic
Try a new key. If that does not work the lock cylinder should be less than $20. If you can install it yourself that is the easiest and cheapest way.
Old Nov 22, 2010 | 10:47 AM
ukrkoz's Avatar
key does not work in what manner?
tumbler does not turn?
tumbler turns but engine does not start?
if tumbler still turns, remove the lock itself and stick screwdriver into the slot. i drove like this for over a year once, when they busted my car.
Old Nov 22, 2010 | 10:57 AM
silverado13's Avatar
how many times have you had your key copied? every time you make a copy of a copy the key you get everytime gets more off everytime then the original
goyakpacking
May 9, 2015 7:51 PM
kcarberry
Jan 24, 2014 5:37 PM
G T Igofast
Sep 3, 2013 3:46 PM
chevykicksbut
Oct 23, 2010 12:32 AM
