knocking/clunking noise when i start driving.
Old Feb 20, 2013 | 5:20 PM
mshaw130's Avatar
Default knocking/clunking noise when i start driving.
ive got an 05 silverado, lifted, 35 inch mud tires. recently went wheeling (which i do every weekend), and got stuck in a pond, was sunk up to the door panels for about an hour before i got pulled out. ever since then i have been hearing a clunking noise when im stopped and then start driving. it doesnt happen all the time but you can feel it and hear it. im thinking its something with the tranny, because ive been underneath and dont see anything loose or broken but im honestly not sure. any ideas???
Old Feb 20, 2013 | 8:19 PM
just a guess... but I had a lifted vehicle make a clunk when starting from a stop and it was the rear drive shaft, yolk slip joint that moves in and out from the tcase output shaft. It was binding and needed a special gm lubricant. the driveline angles change underload and the splined yolk would not easliy move to compensate for the length change.
Old Feb 20, 2013 | 8:25 PM
cleveland63b's Avatar
could be a lot of things...possibly ujoints/driveshaft related...but if you beat on it every weekend you'll just have to start looking
Old Feb 20, 2013 | 10:10 PM
tymr287's Avatar
I have a 91 K5 4WD. A couple of years ago mine was doing the same thing. Turned out it was a broken tranny mount. Have someone power brake it while you look at the mount. My transfer case was hitting the body causing the clunk.
Old Feb 22, 2013 | 1:09 AM
Doug Roberts's Avatar
its the slip yok your ok
silverbirtchz71
Dec 24, 2013 9:13 AM
mojo
Mar 10, 2013 6:42 AM
peterpiepr
Sep 12, 2008 10:04 PM
Courtzilla
Mar 19, 2008 6:08 PM
dzonen
Feb 15, 2007 11:13 AM
