leveling kits for 93 1500
Old Aug 16, 2012 | 3:23 PM
93 1500's Avatar
Default leveling kits for 93 1500
I'm looking to level out my 1993 Chevy 1500 it has the 4.3l v6 I was wondering if anyone can help me out need some advice if you could help me out I would greatly appreciate it
Old Aug 19, 2012 | 4:26 PM
maxxman04's Avatar
is it 2 or 4 wheel drive? are you looking to level the front or rear? for the rear, lift blocks can be used. cheap and easy. as for the front, depends on how much you need to lift. you can buy torsion bar keys off ebay for pretty cheap. give ya anywhere from 2-4 inches of lift. hope that helps
Old Aug 21, 2012 | 12:37 PM
93 1500's Avatar
sorry i havent gotten back to you right away ive been working but its 2wd and its a 4.3 v6 and i would like to lower the back of it
Old Aug 21, 2012 | 8:11 PM
maxxman04's Avatar
you need a pair of lowering shackles then. check ebay. you can get anywhere from 1"-4" drop shackles. typically less than $100. easy, easy to put on.
Old Aug 22, 2012 | 6:58 AM
93 1500's Avatar
Thankyou
Old Aug 22, 2012 | 6:54 PM
93 1500's Avatar
the lowering shackles would bolt right into the old shackles or would i have to cut and weld and would it move the leaf spring below the axle would you know by any chance
Old Aug 22, 2012 | 7:03 PM
maxxman04's Avatar
lowering shackles take the place of the stock shackles. no welding or cutting needed. just unbolt stock shackles from spring and frame, bolt in drop shackles. done. seriously as simple as that.
DJM 2" Drop Shackle Chevy GMC Sierra Silverado 88-98 | eBay
2" is pretty big drop. don't sound like alot, but does make big difference in height.
Old Aug 22, 2012 | 7:10 PM
93 1500's Avatar
alright thanks alot
Old Aug 22, 2012 | 7:22 PM
93 1500's Avatar
what if the leaf spring is on top of the axle and sorry about being a pain in the *** lol but if i put the shackles in wouldnt it just raise the rear of the truck
Old Aug 22, 2012 | 8:18 PM
chevyboy1993's Avatar
the drop shackles are shorter so with the axle under the spring it doesn't matter.
