Lift?
Hello y'all I own a 2008 chevy silverado 6.0l 4x4 and i wanted to lift it up. I changed the tires and I have problem turning because the tires are bigger than the turning ratio, they are 285/75 R17. I instaled a 2" leveling kit with the torsion keys, but saw no difference. Finnally I am looking to get either a 6" inch lifting kit or a 4" kit and get some bigger tires. Any advice?
Thanks
Thanks
So I take it you have a 2500HD if you have keys? And the tires alone won't make your turnin radius better or worse. Now if they're rubbin then yeah that's a problem. If you've put levelin keys on and it still didn't help, then somethin ain't right. Also are you sure that's the tire size? They make a 285/75/16 and a 285/70/17
Are these on stock wheels? That's crazy. Didn't figure a 34" would rub on a 2500hd with keys cranked. But anyways I'd probably a 4" on the same tires and wheels you have now. Or if you can change it up and do a 6" on 35s and either the same wheels or different wheels you have now
58chev
Mar 2, 2012 10:32 AM
Rlock4227
Feb 19, 2012 11:26 AM
