Lift and Performance
Old Feb 17, 2014 | 12:52 PM
cbarnett_2500's Avatar
Default Lift and Performance
Good morning performance people,
I just have a few questions for the experts in performance, but first, a bit about my truck. I own a 2000 Chevy Silverado LT 2500 (Non-HD) with a 364 small block. Already, I have put a high flow intake (by spectre), true dual exhaust, and a custom tuning to the engine. The truck isn't lifted, but it has oversized 33 inch Nitto Terra Grapplers on the stock wheels.
As mentioned above, my truck isn't lifted, but I want it to be. What suspension lift would y'all recommend? I've had a very hard time finding the right lift since my truck is a non-HD 2500. I'm not interested in body lift because the truck will be hitting mud frequently, and I've heard horror stories about mud trucks with body lift. I'm looking for a 6-10 inch lift.
Second, regarding my exhaust, would 4 inch OD 316 stainless steel pipe hurt my engine? My grandpa, back in his prime, worked for a piping company and was given about 60 feet of this 4 inch OD pipe. He's willing to give it to me for free since the people who installed the existing true duals on my truck screwed the piping system up (3.5 inch from headers to cats, 2.5 inch from cats to glasspacks (2 inch inlet/outlet), 2 inch from glasspacks to 3.5 inch tips).
Lastly, I've been researching putting a small turbo system on the truck. Some people say that a small turbo will add a good amount of HP without destroying the engine while others say that even the smallest turbo will blow the engine apart. What do y'all think? Just to specify, before the turbo, I'd be installing a LS6 Cam shaft, an LS6 intake manifold with the 8.1 liter fuel injectors and possibly a new fuel pump.
Please leave your recommendations below, and go easy on me. I'm just trying to learn about what I can and can't do with my truck. Also, I'm not looking for the most expensive for cheapest parts. I'm not a money bag, but I also don't want to buy cheap parts.
Thanks everyone!
Cbarnett_2500
Old Feb 18, 2014 | 4:48 PM
jj0996's Avatar
New User
Awaiting E-mail Confirmation
I would personally just get a 3 or 4 inch lift cuz by the sounds of it that you are going to use it as a daily driver as well, as for the motor just do everything that you were planning on and forget about the turbo you will have enough power with that, and pipes you should be just fine long as you fab them up to your stock headers
Old Feb 23, 2014 | 9:14 PM
I'm turning the truck into a dedicated mud-machine. I've thrown out my old idea of finding a lift and am currently designing a custom 18 inch lift.
My question still stands: will a turbo, whether I decide to install one or not, blow my engine apart? If so, then I'll be trashing that idea, but, on the off chance that it won't, I'd still like to do it for added power when I sink into two feet of mud.
Thanks for the response, jj0996! I appreciate your help! I'll be installing the piping within the week, hopefully!
Old Feb 24, 2014 | 7:53 PM
country_09's Avatar
Turbo won't blow your motor with proper tunin and proper boost for the motor and supportin mods you have on the truck. Should actually run great if done correctly. I have 2 buddies that DD turbo'd trucks
Old Feb 24, 2014 | 8:51 PM
Awesome! Thank you so much for your help. I really appreciate it!
Old Feb 24, 2014 | 9:56 PM
Charlie5280's Avatar
With that engine......all you need really is a nice set of heads (AFR CNC), and a good cam....you'll make BIG power
Old Feb 25, 2014 | 11:35 AM
How much power do you speculate I'll be making? I'm producing 380 RWHP atm and would like to be at 600-700.
Just for reference, I'm putting 67 inch tractor tires on the truck and will be sinking it often. I'm gonna need alot of power to compensate.
Old Mar 5, 2014 | 8:02 AM
Bump <3
Chevrolet Forum News
Oct 9, 2013 7:08 AM
58chev
Mar 2, 2012 10:32 AM
Rlock4227
Feb 19, 2012 11:26 AM
cyras21
Dec 27, 2007 9:15 AM
