Old Aug 10, 2015, 6:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Transmission Guides
Print Wikipost
Loud clunk in driveline, 2007 Silverado
Old Feb 5, 2011 | 5:14 PM
jnichols495's Avatar
Default Loud clunk in driveline, 2007 Silverado
I am new to the foum, and have a 2007 Silverado (new body style) Crew Cab "Texas Edition" 2WD LT2 5.3 liter with 40000 miles. I am having a problem with a loud clunking noise coming from the driveline. In a nutshell, when I come to a complete stop, I hear / feel a loud clunk coming from the rear end, as if the transmission is engaging abruptly. It will occur while stopped or when starting from a dead stop, and it will do this about 10% of the time. I am afraid that the dealer might not be able to duplicate the condition if I take it to them. Has anyone here heard of this problem?
Old Feb 5, 2011 | 7:54 PM
2500_Gasser's Avatar
Default Clunk
Not sure about what exactly is causing it but I have a 2007 Silverado nbs crew 4x4 Vortec and I hear a thump when stopping or shortly after a stop. Not all the time but sometimes. I have heard that it may be torque converter and normal. Sorry no answer but I thought it might help to let you know that, if we are hearing the same thing, there are others out there.
Old Feb 5, 2011 | 11:05 PM
Bigredmariner's Avatar
Sounds like the dreaded "Clunk" our trucks are notorious for this condition. You need to remove the driveshaft and clean and grease the splines on the yoke that slips into the transmission. It should cure your problem. The splines get dry and it will cause a "clunk" when you come to a stop and sometimes you feel it on take off.
Old Feb 6, 2011 | 9:59 AM
ristpin's Avatar
My '04 Silverado had the same issue. I thought it was a serious transmission problem. Greased the spline like was mentioned, problem went away. It seems to be a routine maint. thing, I had to re-do mine after about a year or so. Hope it fixes your problem.
Old Feb 6, 2011 | 12:25 PM
Thanks for the tips. I have read about cleaning an re-greasing the spilnes in the past, but was unsure if it was really the fix I needed. I purchased the extended GM warranty when it was new, will GM cover this under warranty?
Old Feb 6, 2011 | 12:41 PM
ristpin's Avatar
I doubt it. Nothings broke, just needs lube. Bad design or something. "Normal maint."? Good luck with the warranty!
Old Feb 6, 2011 | 1:46 PM
I had read there was a TSB out for an upgraded yoke, I don't have the number of it. But there was supposedly a special coated yoke that they could install that would help. I just never wanted to deal with the hassle of taking it in so I grease the thing from time to time.
Old Feb 7, 2011 | 10:54 AM
Official GM Rep
jnichols495, I would suggest speaking with your dealership to see if you may be covered for this type of fix under the 5 year 100,000 mile powertrain warranty. I did look over the warranty coverage and it looks like you should be covered for a fix like this but for the final say in the matter I would, again, suggest you speak with your dealership. I hope that helps you and if you run into any other issues feel free to contact me.
Jeff Morris, Chevrolet Customer Service
Old Mar 13, 2011 | 9:49 PM
Well, I spoke with my local Chevy dealer (Palm Chevrolet in Gainesville, FL) and while they were aware of the issue, it would not be covered under warranty. So, I removed the four 11mm bolts holding the rear u-joint to the rear yoke, removed the very long (but very light) aluminum drive shaft, cleaned and greased the splines and re-installed the driveshaft. After two weeks of in town driving, the clunking is gone. While I am glad that I no longer have to live with this very annoying issue, I am more that disappointed in the lack of customer service I have received from Chevrolet. Knowing that I paid extra for the extended warranty, and knowing that they are aware of this problem, I can't help but feel cheated by them. So much for my over 35 years of loyal GM ownership. Perhaps a new Toyota is in my immediate future after all.
Old Sep 20, 2012 | 7:21 PM
bobino's Avatar
Hi there! I just bought a 2011 silverado 1500, 5.3 lt. Its a automatic tranny with a manual 6 speed (touch of a button). I heard the same clunking kicking motion coming from the back. At one point of time, it was coming from beneat me(under between passger and driver seat). Brought it back to dealler to be charge 117.65 for a miss diagnose. Just did first oil change and was told to bring it back to gm asap. At a different Gm place got told that yoke is mangle and were its connecting to transfer case is grease everywhere arround shaft. Warranty is covering it , but the issue will always resurface because according to Gm its normal for the kicking motion. Belleive it Gm as never fixt that problem and if I would of known would of never buy a Siverado crap. Dam I wish they of told me that before I signed the contract.
Oh well, my next truck surely wont be A LEMON FROM GM
