Lubing driveshaft spline & window runs out of track
Old Jul 14, 2010 | 2:54 PM
ristpin's Avatar
Default Lubing driveshaft spline & window runs out of track
2004 Silverado, 5.3, auto. I want to lube the driveshaft front spline (yoke) and am asking if I will be in any suprises? Or is it pretty straight forward? Unbolt at the rear end, pull it out, lube and re-install. 2nd question, the passenger side window sometimes runs out of the track when going up (at about the 3/4 point). Any easy fix for it? Thank you.
Old Jul 14, 2010 | 5:17 PM
snakedoctor's Avatar
If you can't use the GM recommended slip yoke grease part # 12345879 (its expensive) The pint I have was 37 bucks, Use a marine grade high temp water proof grease. The grease you get for chassis lubrication in the Autozones and Walmarts will break down and could get in the trans.
http://www.truckmodcentral.com/forum...ead.php?t=2504
Old Jul 14, 2010 | 6:25 PM
ristpin's Avatar
Thanks for the info. I went to the site you listed. Very informative.
Old Jul 14, 2010 | 6:32 PM
Excellent link snakedoctor very informative
Bikedude987
Mar 16, 2015 10:13 AM
bans25
Uplander
Jul 15, 2011 7:40 AM
Dust1905
Mar 17, 2010 2:05 PM
Cbaker84
Jan 29, 2008 7:35 PM
techcons
Dec 31, 2007 1:23 PM
