Need tire suggestions
Hi, I bought a used 1991 Silverado k1500 4x4. The tires are worn P265/75 R16 114S. I'd like to replace them with a set of LT tires. Which LT tire sizes can I use without changing rims?
Thanks
80skeys
Thanks
80skeys
I think you need to worry more about the clearance of the fender wells if you go any bigger than the 265/75 and not the size of the rim on that year of truck, you may be able to squeeze a 285/75 in there but the tread can't be real deep. On a 97 I had I put 265 /75/16 Buckshot Maxxis Mudders on them and only had about an inch to two inches of clearance when the wheels were fully turned in the stock fender wells.
jrmoeller23
August 11th, 2010 4:32 PM
