Need tire suggestions
Old Apr 5, 2010 | 11:35 AM
80skeys's Avatar
Default Need tire suggestions
Hi, I bought a used 1991 Silverado k1500 4x4. The tires are worn P265/75 R16 114S. I'd like to replace them with a set of LT tires. Which LT tire sizes can I use without changing rims?
Thanks
80skeys
Old Apr 5, 2010 | 11:48 AM
Sirius018's Avatar
I think you need to worry more about the clearance of the fender wells if you go any bigger than the 265/75 and not the size of the rim on that year of truck, you may be able to squeeze a 285/75 in there but the tread can't be real deep. On a 97 I had I put 265 /75/16 Buckshot Maxxis Mudders on them and only had about an inch to two inches of clearance when the wheels were fully turned in the stock fender wells.
Old Apr 5, 2010 | 4:52 PM
mudmaniac's Avatar
Ride of the Month
May 2009
You should have no trouble with BFG ATs 285/75/16, they aren't cheap but you'll get 45-50k on them if you rotate them often.
Old Apr 7, 2010 | 8:31 AM
davbell22602's Avatar
I'd stay with the 265/75/16 and get the general grabber AT2 tires from tirerack.com
zr800
Oct 26, 2010 5:18 PM
jrmoeller23
Aug 11, 2010 4:32 PM
bwaterfowler15
Jan 31, 2010 8:22 AM
Rolling Thunder
Apr 5, 2008 4:25 PM
bigmuley
Nov 3, 2007 11:59 PM
