Notices
New Leaf Springs
Old July 13th, 2011, 1:30 AM
SILVERAD01's Avatar
Default New Leaf Springs
I'm about to purchase a set of new/used leaf springs. I've changed shocks, bushings, and greased everything in the rear and yet there is still an annoying loud "squeek". It only goes away if the leaf springs get wet but once they're dry it's back to squeeking. So my question is, Can I possibly fit leaf springs from a 2500 or heavier onto my 1500 since I pull my trailer quite a bit? (2001 Ext. Cab short bed)
Old July 13th, 2011, 8:41 AM
old dog's Avatar
Default springs
the 2500 springs should go right in there no problem !we used to do it all the time at the spring shop i worked at all the time .
Old September 9th, 2011, 1:01 AM
SILVERAD01's Avatar
I bought a set (not sure if they are from a 1500 or 2500 put there is 1 extra leaf in the pack) and they went right in, sqeek is GONE !!! finally. I love my truck again. The whole truck was sitting at an angle but is now straight and stiffer. In case anyone else might have this problem I hope you read this post to make your headaches go away.
Old September 9th, 2011, 7:16 AM
therewolf's Avatar
Hi SILVERADO1,
Welcome to the Chevy Forums.
At the 4WD store you can get new rubber pads
for the ends of the springs which will help cut
down squeaking noises.
kdzapala
June 29th, 2011 7:12 PM
purdy64
January 13th, 2011 9:01 PM
lawsona
June 25th, 2008 7:51 PM
lawsona
June 25th, 2008 5:30 PM
turbinesurgeon
May 20th, 2006 6:35 PM
Quick Reply: New Leaf Springs
