noise on my silverado when turning steering wheel
Old Jan 10, 2012 | 8:09 PM
manthny18's Avatar
Question noise on my silverado when turning steering wheel
I get like a humming noise when i turn my sterring wheel been happening for a while. 03 chevy silverado reg cab arival blue. lmk soultion if anyone ever had this problem and has fixed. Thank you
Old Jan 10, 2012 | 10:00 PM
Cpb200's Avatar
well idk what type of noise your hearing but on my dads 03 his makes a noise but its the sound of the power steering pump when turning sharp or when useing the breaks and turning hard sence gm uses a master cylander
im not sure if its the same for you but this may be it
Old Jan 11, 2012 | 2:17 AM
1994medtec's Avatar
steering stabilizer, power steering pump, pitman arm, check 'em all
Old Jan 11, 2012 | 5:19 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> manthny18,
Cpb200 and 1994medtec both offer great suggestions. The steering gear is also a possibility. You may want to consider taking the vehicle in for an inspection. A certified technician should be able to offer a more accurate diagnosis.
If you have additional questions or concerns, feel free to contact me.
Louis
GM Customer Service
Old Jan 12, 2012 | 11:28 PM
manthny18's Avatar
thank you guys ill give them all a try and ill let you guys know out come,
bbschevy1
Jul 19, 2022 7:16 PM
Impowa
Mar 23, 2010 8:35 PM
dspahos
Jan 2, 2010 7:58 AM
jla74
Apr 7, 2009 8:08 PM
