O2 sensor
Old Jul 18, 2012 | 9:39 PM
zraddy's Avatar
Default O2 sensor
What does the o2 sensor do. i put new exhaust on my trucj and the garage said it isnt nessisary to put it on
thanks
Old Jul 18, 2012 | 11:12 PM
country_09's Avatar
Measure the air/fuel ratio for your truck. The fronts do anyways. The rears make sure the cats are workin correctly. you don't absolutely need the rear o2s but will throw a SES light without a tune
Old Jul 19, 2012 | 11:36 AM
WalkerTech's Avatar
zraddy,
I am a Product Specialist with Walker Products, a manufacturer and worldwide distributor of oxygen sensors. As country said, the oxygen sensor's purpose it so monitor the air/fuel ratio in your exhaust. The benefit of this to you is healthy, smooth running engine with optimum fuel efficiency. You could certainly do without these things if that were your choice. However, if your truck is a modern vehicle then you will get a CEL due to the missing sensors. What exactly do you drive?
Old Jul 19, 2012 | 2:37 PM
ericnottelin's Avatar
Country hit it right on the head. The fronts (between the exhaust manifold and cat) measure the air/fuel ration and the computer adjusts accordingly to those two. The rears (just after the cat) measure the temp of the cat and make sure they are working correctly. IF your exhaust deleted the cat and/or these last two O2 sensors, you WILL need a custom tune to resolve your problem
Hope this helps
Eric
Old Jul 19, 2012 | 9:17 PM
the only thing an oxygen sensor can measure is oxygen content.
in reguards to the catalytic convertor; the ecm compares the cross counts (lean to rich transitions) of the front and rear sensors to determine if the catalytic convertor is functioning (oxidizing hydrocarbons in the exhaust stream).
if you want to add the o2 sensors to the new exhaust; threaded fittings are available that can be welded into place.
Old Jul 21, 2012 | 9:26 PM
zraddy's Avatar
my truck doesnt have the cat converter or the 02 sensor just cut them off while putting new exhaust on
Old Jul 21, 2012 | 9:35 PM
Yeah man, your going to need a custom tune with the rear o2 sensors deleted. This will be needed to turn off the infernal check - engine light
Old Jul 21, 2012 | 11:11 PM
MDTAHOE's Avatar
Professional Mechanic
What year is the truck. You must have them if the truck is OBDII. If it is not you should have them but could get away without even though I would recommend not to.
Old Jul 22, 2012 | 6:56 PM
zraddy's Avatar
Its a 1995 k1500 with a v8 350 in it.
What does OBDII mean ???
Old Jul 23, 2012 | 5:52 AM
OnBoard Diagnostic 2
