o2 SENSOR REPLACEMENT
Old Feb 12, 2012 | 9:20 AM
Jimbos01hd's Avatar
Default o2 SENSOR REPLACEMENT
I have the 135 and 155 codes coming up so new sensors are in the future. my question is should I go with direct repacement of the universal fit ones? the Universal ones are alot cheaper but I dont wnat to screw with crimping and cutting wires one a sensor that I thought ran off resistance. Any recomendations.
Old Feb 12, 2012 | 9:29 AM
didn't even know they had anything but direct fit.
the sensor output voltage is so low that any added resistance from improper crimping will skew the readings. If it was me; direct fit.
Old Feb 13, 2012 | 6:02 PM
Fishinfooleric10@aol.com's Avatar
Use the direct fit, the hassle is not worth the money you will save. Buy the direct screw em in and plug em in and go with it. The couple of extra bucks will save you the headache.
Old Feb 17, 2012 | 6:08 AM
Jimbos01hd's Avatar
couple of extra bucks?? they are almost twice as much from discount. 80 some dollars. I decided to see how much they were at the dealership figuring I would definately get the right parts... $117. Im thinking a $1 roll of electrical tape witll fix the light problem. I grabbed one of the Denso direct fits. My MIL shows it as both side up stream heater elements are not working so Im going to replace the one side and hope that it gets one of the 2 codes off before I drop the other 80 for the other side.
Old Feb 17, 2012 | 6:23 AM
shamrock246's Avatar
Try amazon even with shipping they were cheaper autozone
Old Feb 17, 2012 | 8:08 AM
If you are wanting to be a frugal as possible you could try removing and cleaning the O2 sensors and see if that helps any or at least buy you some more time with them... I have never done this but have read that it is a plausible fix..
Don't use anything that can leave a residue...
Old Feb 17, 2012 | 10:55 PM
MDTAHOE's Avatar
Professional Mechanic
Heard the saying you get what you pay for. If you buy junk you get junk
Old Feb 18, 2012 | 8:10 AM
Jimbos01hd's Avatar
its the wiedest thing.. Unplugged the passenger side to remove it but couldnt get it loose with the O2 sensor socket due to tight space so I plugged it back in them went to the drivers side and easily removed it and installed the new one. last time I had the computer reset it was back on withing a few miles showing the same 135, 155 and 300 codes. Had it reset this time. All the codes stayed off all the way home. I took it for a 40 mile drive later and all the codes stayed off.. This morning the codes were off again but soon came back on but Im thinking for a different reason. Ill have them read and report back.
About being frugal.. If I knew that the problem was the sensor I would drop the cash on it but its showing up as the heater circuit on the sensor and there seems to be a few issues that could cause it to show a bad code so before I dumped $250 into it I wanted to make sure it wasnt a wiring issue with it.
kburger123
Nov 2, 2012 8:06 PM
ldearman
May 5, 2011 4:08 PM
gossimer
Nov 12, 2010 4:47 PM
jffgin
Mar 10, 2008 2:32 PM
