OB1 error code 34
Old Nov 4, 2015 | 7:52 AM
simtech's Avatar
Default OB1 error code 34
1995 GMC Serria C1500.
My son took off the exhaust manifold without disconnecting the battery. It fell on the positive lead from the battery. It shorted. I am now getting code 34, which states: MAP sensor - voltage low. Wiring open circuit/short circuit to ground, MAP sensor, ECM.
I replaced the MAP sensor, still have the code. Could the ECM be bad since there was a short from the battery? The exhaust manifold was to hot to handle from the current running through it.
