oil in antifreeze? 98 5.7L
Old Dec 22, 2010 | 1:39 AM
kevin1741's Avatar
Default oil in antifreeze? 98 5.7L
I have oil in the coolant but do not have coolant in the oil? Any ideas? Thanks.
Old Dec 22, 2010 | 7:19 AM
old dog's Avatar
Default oil in anti freeze
only thing i can think of is if you have a trans cooler with lines going to the radiator ,the older car's and truck used to have a pancake cooler in the radiator that some time,s would leak oil into the radiator .
then the later models started coming with external coolers .
Old Feb 26, 2012 | 4:22 PM
Rocco 2's Avatar
I have a 2000 Chevy truck I think the cooler seal is leaking water into the transmission.
Old Feb 26, 2012 | 8:21 PM
gavinjames's Avatar
could be head gasgket
Old Feb 26, 2012 | 10:19 PM
avgas's Avatar
I would be checking the engine oil cooler if it has one in the rad or the trany cooler. I would not jump to the head gaskets. Check the simple things first. Is it engine oil or trany oil? It might be hard to tell if the trany oil is dark but I would suspect a cooler issue.
Old Feb 27, 2012 | 12:03 PM
slw210's Avatar
I don't believe a head gasket will allow water into the transmission.
Unless you drove through some water that was up to the vent or someone just poured water in through the filler tube, most likely sucking coolant into the transmission through the radiator. Only ways I ever heard to get water in the transmission. (if you have an Automatic transmission).
Que_66
May 30, 2008 3:37 PM
lw62
Feb 24, 2008 10:18 PM
Iajeeper
Mar 3, 2007 5:06 PM
jorgie5150
Jan 27, 2007 5:18 PM
kdeinv
Dec 31, 2006 10:09 PM
