Oil change?
Old Jan 13, 2008 | 3:00 PM
northey87's Avatar
Default Oil change?
I was wondering how much oil should a 5.7 engine need? I would assume that It would be 5qts. which isall it took, but apparentlyit has a oil cooling systemandrequires a larger then normal filter, but with the cooling system and larger filter wouldn'tit take more than 5qts.? And what should my oil pressure be? This last oil change I put mobile 1 in and when it is running cool the oil presure is around 60psi but after it warms up it drops to around 40 psi. is this normalwhen using a full synthetic oil? Thanks.
Old Jan 13, 2008 | 3:03 PM
clintjohns6412's Avatar
Default RE: Oil change?
DEPENDS ON WHAT THE VEHICLE IT IS IN. IF IT HAS STOCK OIL PAN. SHORT OR TALL FILTER. OIL PSI CAN BE ANYWHERE FROM 25-40+ PSI AT IDLE.
Old Jan 13, 2008 | 4:20 PM
cgcomeaux's Avatar
I have a 2006 silverado 5.3 liter and I just did an oil change today. I used mobil fully syn. and it took 6 quarts. I would think yours should take at least 6 quarts, but read your owners manual under specifications/ oil capacities.
Old Jan 13, 2008 | 5:26 PM
northey87's Avatar
I guess itonly takes 5qts. Every time I check the dipstick it show that it is at the right level. Theengine is in a '95 1500, with an oil cooler system. It just seems odd that oil presure would only be at 40, but then again this is the first chevy I have owned and the first time I have use Synthetic oil in any of my vehicles.
Old Jan 14, 2008 | 6:25 AM
tedinindy's Avatar
5 qts of oil including filter is correct for the 5.7. You've got good oil pressure, it is right where it should be for that engine in very good condition. Different oil brands or wieght ( 5w-30, 10w-30, 10w-40, etc..) won't make the pressure vary all that much. The pressure will drop slowly over time as internal engine componentswear. Really low pressure (<15 at 2000 rpm)on a fully warmed up engine usually means worn crank bearings and piston rings. A major rebuild or short block would be needed. Regular oil changes with quality oilhelps minimize internal engine wear, and oil pressure loss.My98 silverado with a 5.7 vortec when it was new, had oil pressureof 50 - 55 psi warm at 2000 rpm, 70 - 80 psi cold at startup.I changed theoil every 3000 miles and alwaysuse 4 qts 5w-30 valvoline duralube synthetic blendand 1 qt lucas heavy oil stabilizer.I'm at225,000 mileshaving done nothing but scheduled maintenence. The oil pressure fully warm at 2000 rpm is around35 psi.Coldpressure around50psi. I'm told by my local Chevy service departmentanything 20 psi or > fully warm at 2000 rpm is within safe operating oil pressure specifications. Hope this helps.
Old Jan 14, 2008 | 10:01 AM
northey87's Avatar
Thanks for all the help, now I know.
in2pro
Nov 19, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
Feb 6, 2010 1:10 PM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
digdug
Feb 4, 2007 3:08 PM
Top
Follow Us
