oil change
Old May 5, 2008 | 11:01 PM
elcalote99's Avatar
Default oil change
i just did my first oil change on my 04 silverado before the warning came onhow do i reset the oil life sensor?
Old May 6, 2008 | 7:00 AM
bad2006z71's Avatar
Default RE: oil change
if you do not have the steering wheel controls. turn the key to the run position but do not start it, then press the gas pedal either 3 or 5 times in 5 secs and "oil life reset" will flash on you DIC. it has been reset.
if you have the steering wheel controls im not sure (since i dont have them) but it should be in the menu somewhere there
good luck.
Old May 6, 2008 | 9:24 AM
ax7221's Avatar
Remember, if you dont have the DIC you have to press the pedal to the floor for it to work, and If I remember correctly, its 5 times.
Old May 6, 2008 | 5:22 PM
elcalote99's Avatar
I did that and the oil life reset does come on but it does not flash and it stays on does that sound right?
Old May 6, 2008 | 11:38 PM
ehhget's Avatar
It is 3 times on my truck and try turning your key to the first click not to the run position, every time I reset mine it takes me a few tries.
in2pro
Nov 19, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
Feb 6, 2010 1:10 PM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
digdug
Feb 4, 2007 3:08 PM
