oil change
[align=left]i ve had my 02 chevy silverado for about a month and it didnt come with the owners manual the change oil light came on so i changed it. so can anyone tell me how to reset the light and how much oil it holds. its a 4wd ext cab 1500. thanks
[/align]
[/align]
Here ya go:
If you go to www.mygmlink.com, you can register your vehicle and view the owner's / service manual online.
How to Reset the CHANGE ENGINE OIL Message
The GM Oil Life System
calculates when to change
your engine oil and filter based on vehicle use. Anytime
your oil is changed, reset the system so it can calculate
when the next oil change is required. If a situation
occurs where you change your oil prior to a CHANGE
ENGINE OIL message being turned on, reset
the system.
To reset the CHANGE ENGINE OIL message do
the following:
1. Turn the ignition key to RUN with the engine off.
2. Fully press and release the accelerator pedal three
times within five seconds.
If the CHANGE ENGINE OIL message flashes for
five seconds, the system is reset.If you go to www.mygmlink.com, you can register your vehicle and view the owner's / service manual online.
in2pro
November 19th, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
February 6th, 2010 1:10 PM
Toby T
March 14th, 2008 5:16 PM
Big D
January 10th, 2008 6:53 PM
digdug
February 4th, 2007 3:08 PM
