oil change
Old Aug 5, 2007 | 6:11 PM
jaydogg892's Avatar
Default oil change
[align=left]i ve had my 02 chevy silverado for about a month and it didnt come with the owners manual the change oil light came on so i changed it. so can anyone tell me how to reset the light and how much oil it holds. its a 4wd ext cab 1500. thanks
[/align]
Old Aug 5, 2007 | 6:48 PM
07tahoe's Avatar
Default RE: oil change
Turn the key to the accessory position thenpressthe gas pedal 3 times, that should reset it.
Old Aug 5, 2007 | 7:33 PM
jaydogg892's Avatar
that didnt work any other ideas?
[align=left] [/align]
Old Aug 6, 2007 | 1:07 AM
RonH's Avatar
Here ya go:
How to Reset the CHANGE ENGINE OIL Message
The GM Oil Life System
 calculates when to change
your engine oil and filter based on vehicle use. Anytime
your oil is changed, reset the system so it can calculate
when the next oil change is required. If a situation
occurs where you change your oil prior to a CHANGE
ENGINE OIL message being turned on, reset
the system.
To reset the CHANGE ENGINE OIL message do
the following:
1. Turn the ignition key to RUN with the engine off.
2. Fully press and release the accelerator pedal three
times within five seconds.
If the CHANGE ENGINE OIL message flashes for
five seconds, the system is reset.
If you go to www.mygmlink.com, you can register your vehicle and view the owner's / service manual online.
Old Aug 6, 2007 | 5:51 PM
kcb37's Avatar
I am going to assume you have a 4.9 or a 5.3 v8. If so they should take 5 qts.
Old Aug 6, 2007 | 9:34 PM
jaydogg892's Avatar
thanks alot that worked you guys rock
Old Aug 9, 2007 | 7:29 AM
mygreenihc's Avatar
You might want to verify this...I have an 02 with a 4.8 and it takes 6 quarts.
in2pro
Nov 19, 2015 5:36 PM
PeterPiper
Sonic (Aveo)
17
Feb 6, 2010 1:10 PM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
digdug
Feb 4, 2007 3:08 PM
