oil change message???? need help
Old November 26th, 2007 | 12:44 PM
owens87's Avatar
Default oil change message???? need help
i have a 03 silverado with the message center in the dash tell "low fuel level and all that and i just changed my oil and i was needin to kno how to get the "change engine oil" message to stop showin up when i turn my truck on my truck dont have the little buttons on the column it just has the trip reset stick how do i get this to stop showin up....thanks for ur help...
Old November 26th, 2007 | 12:53 PM
engine2's Avatar
Default RE: oil change message???? need help
PM ZX. I am not sure if it came for done the old way by using the ignition and gas pedal to reset. But ZX will know for sure.
Old November 26th, 2007 | 9:43 PM
maradison's Avatar
You have to turn the ignition switch to the on position (not started) then you push the gas pedal to the floor, I believe it is two times. Then the display will tell you that the oil monitor has been reset.
Old November 27th, 2007 | 1:23 AM
hines182's Avatar
should be 3 times.. either way the oil life will reset and i think it blinks at you... either that or it automatically toggles to the oil life and shows it at 100% I'm pretty sure that works for up to the '06 models... i'm not sure about '07 and up, i didn't work on those much
James Eagle
October 27th, 2014 1:16 PM
06hhr
HHR
August 5th, 2010 1:36 AM
edcorsaro
August 21st, 2007 8:52 AM
digdug
February 4th, 2007 3:08 PM
koobiidoobii
April 28th, 2006 10:23 AM
Quick Reply: oil change message???? need help
