Oil pressure fluctuation
Old Mar 3, 2012 | 6:58 PM
2007silerado's Avatar
Question Oil pressure fluctuation
I have a 2007 Chevy Silerado that I just replaced the lifters and cam on..
Last night we refilled the oil and started the engine and it sounds great, only problem is that the oil pressure gauge keeps staying between 20 and 40 and when I stop to idle it drops but when I accelerate it goes back up to around 30 and it used to stay at 40.
We did not change the oil pump as it was fine before..
I put a hgh mileage 5 w 30 oil in it... Would that make a difference
Old Mar 4, 2012 | 11:57 AM
cleveland63b's Avatar
what oil were you using before? I doubt that changed anything
Old Mar 4, 2012 | 2:56 PM
Penn 5w30. Kiwi car usually changed it
Old Mar 4, 2012 | 3:21 PM
ukrkoz's Avatar
it's fairly normal. Mine does same. Sits at about 20 idle, then goes up as you step on it. Colder outside - higher cold start pressure. Same goes for battery gauge - sits at about 14 after start up, then drops down to 12 or so.
Old Mar 4, 2012 | 4:15 PM
MDTAHOE's Avatar
Professional Mechanic
Sounds like normal operation
Old Mar 4, 2012 | 6:14 PM
Thanks folks... Just bothered me since it used to stay at 40 until I replaced the lifters and cam
Old Mar 4, 2012 | 6:16 PM
I also replaced the timing chain but NOT the oil pump... It sounds great running so I just wanted some opinions from other Chevy owners
hwkchief
Mar 8, 2015 8:57 PM
Yogi
Feb 14, 2014 3:07 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
Scany
Sep 11, 2008 3:10 AM
cblu007
Jul 26, 2007 8:11 PM
