oil pressure problem. need help
Old Feb 23, 2011 | 6:18 PM
rfordy's Avatar
Default oil pressure problem. need help
the oil pressure in my 2004 chevy 1500 is dropping. i got my oil changed 1000 miles ago and it has plenty of oil. it is usually around 38 psi while under idle and warmed up. It is dropping to about 32psi and at one point it dropped to 20psi. I usually change my own oil and i always put in good oil with a bottle of treatment. I had an oil change place do it this time. please help. thank you.
Old Feb 23, 2011 | 7:29 PM
OLD WRENCH's Avatar
Default oil press
Change it yourself so you know what is in it. If you still have problems hook a good mechanical gauge to it so you know what is going on. I changed the sender on mine and lost 20 lb. of press.
Old Feb 23, 2011 | 8:49 PM
tsduke's Avatar
I think the big thing to remember is these are not mechanical pressure gauges and are not perfect.
My new 5.3 motor in my 05 with 6k on it runs about 26psi hot idle and around 40 down the highway. Not much different than previous motor.
Old Feb 24, 2011 | 10:57 AM
rfordy's Avatar
but why the sudden drop i guess is my question
Old Feb 24, 2011 | 11:13 AM
tsduke's Avatar
Typically not an engine problem. Either cluster issue or sending unit would be the place to start.
Old Feb 28, 2011 | 8:09 PM
rfordy's Avatar
its gotta b the cluster, i noticed when i had alot of running around to do one day. I started loosing push when i pulled into a gas station, i turned it off and the oil press guage went way past zero. got gas drove it to the bank, had great push, turned my truck off and the guage went to zero and so on and so on. thats for the help guys
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
medicman681
Aug 4, 2013 2:09 AM
SilveradoGirl
Sep 21, 2009 11:50 AM
trolea1234
Mar 3, 2009 10:58 AM
