Notices
oil problems ('96 v8 5.7 silverado)
Old February 22nd, 2011, 4:48 PM
  #11
snunicycler's Avatar
ya, when he said he couldnt tell for sure without looking at it i said no thanks. if the gaskets are good i still have to pay for all that labor/parts on top of what else is wrong.
as far as the sending unit, i assume that it is still ok to drive right? i can replace it over the weekend. i forgot to check for smoke on my lunch haha, but i'll check after work before i drop it off to get the oil changed. the truck still drives the same regardless of what the gauge says.
Old February 22nd, 2011, 6:44 PM
  #12
princessauto's Avatar
you have to go to your local auto parts store and ask for a manuel oil guage. if you want to you can email me your phone number i will call you and explain in more detail
princessauto
Old February 23rd, 2011, 9:23 AM
  #13
ok, last night i checked for smoke. there was none when i first started it up and there was none after i drove it around for a while. i got an oil change and even though i was doing it early, it was pretty low. i havent seen the check gauges light come on but the gauge does still flicker around quite a bit. the check engine light was off after the oil change but is on now. i dont know what they would have done that would have made it go off.
i will check for bubbles under the oil cap on my lunch break today. might also do the carbon monoxide detector test tonight.
Old February 23rd, 2011, 7:49 PM
  #14
OLD WRENCH's Avatar
Default oil pressure
The thing that troubles me is your symptom shows up when stopping or starting. This would point me to trouble in the oil pan. Baffel or pick up tube maybe.
Old February 24th, 2011, 9:13 AM
  #15
oh ok, i'll do some research on those. thanks for the info! this morning i found out that the CEL problem only happens while i am idling. sometimes the light will turn off and if i can drive for a while without having to stop it will stay off until i come to a red light and have to idle for more than a few seconds.
Mom2ThreeACG
Traverse
March 12th, 2018 6:20 PM
Casual Mechanic
June 22nd, 2015 11:20 AM
mwehrste
December 29th, 2014 11:19 AM
Dallas4
October 23rd, 2012 1:45 PM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: oil problems ('96 v8 5.7 silverado)
