poor idle
Old Mar 1, 2012 | 2:11 AM
kashman's Avatar
New User
Awaiting E-mail Confirmation
Default poor idle
ok this is the deal 2000 silverado 2500 4x4 6.0 gas
idle drops when the trans gets 2 temp 500rpm to 300rpms only in gear. now what iv done iac, rubber grommet for the butter fly, clean TB took off truck cleaned very good, egr, plugs, no dummy light
Old Mar 1, 2012 | 6:57 AM
recondrill's Avatar
One thing I've learned is that when you clean throttle body, disconnect the battery, remove the TB to clean completly, reassemble, then re-connect battery. When the TB gets gunked up, the PCM changes a lot of settings, so when the TB is cleaned and gets cleaner air, the PCM has to be re-set (why to disconnect battery) to re-learn all atmospheric settings, again.
hope this helps.
Old May 8, 2012 | 2:07 PM
kashman's Avatar
New User
did a reset still not fixed
Shinare
Sonic (Aveo)
Feb 13, 2021 9:16 PM
PA Mountaineer
Nov 25, 2010 4:42 PM
ashortkid
Dec 27, 2008 1:06 PM
hatleyjm2000
Mar 25, 2008 10:31 AM
Joshewuhh
Sep 23, 2006 10:18 PM
