Power Window Motor?
#11
I had to buy the whole unit cause the cable broke, and window fell into the door, scared the S@#t out of me when it happened to. took less than 20 minutes to replace the drivers door, and I swapped the fact speakers at the same time very easy to install just dont overtighten the bolts cause they can bind the tracks inside.
#12
Thanks for the help guys, I just cleaned her and lubed her up, seems to be working fine now. I hope it stays that way.... we'll see.
#13
Excellent, got to love a fix that only cost a bit of elbow grease....
Might want to do the others also, once done they will probably be okay for a year or so but it depends on the environment that you drive in.
#14
Now this is what I like to see, we saved you (and hopefully a few more folks) money.
Don't be shy, CoffeyLover. When you can help by sharing your experience, jump in. Maybe I'll save money next. It wouldn't be the first time.
#15
Will do, thanks for all the help.
#17
well i lubed up the tracks and nothing. the windows still seem to be going down slow. any more suggestions? i did all four of them by the way. im thinking maybe would have to change the window motors but i have no funds for that so i went the cheap way. :-(
#18
if you read the whole post, you might need to replace the whole unit. the motor is not the problem most of the time. alot of times it seems to be the cable, and you have to buy the whole unit with cable, track, and motor. if the grease did not work I think this might be your fix. alot of times when you get the door apart you can see the cable and tell if it is starting to go bad.
davbell22602
March 10th, 2010 8:36 PM
melat70
August 14th, 2007 11:26 PM
melat70
August 11th, 2007 11:38 AM
