problems with a chev 1500
Old Mar 18, 2008 | 11:40 PM
cooper173's Avatar
Default problems with a chev 1500
Okay, I just got a 99 the other day its a 1500 4x4. When i pulled out of the guys drive way when i bought it, it started up just fine but now sometimes it will take a few trys to start it. i know its not the battery or the starter because it turns over just fine. sometimes it wil start up but then lose RPMs and die, and other times it will take 10-20 seconds before starting.It has new plugs and fuel pump. I was thinking maybe spark plug wires? So does anyone have any idea's?
Old Mar 19, 2008 | 5:48 AM
Fourmac's Avatar
Default RE: problems with a chev 1500
Could bethe fuel pressure regulator.
Old Mar 19, 2008 | 10:34 PM
cooper173's Avatar
Okay thanks I will take a look at it. Any other ideas?
Old Mar 19, 2008 | 10:53 PM
TransAm Man's Avatar
It does sound like your fuel pressure regulator is sticking shut.
Old Mar 19, 2008 | 10:59 PM
rjsasaoka's Avatar
Just throwing this out there, but what about the Intake Manifold gasket or distributor?
Old Mar 19, 2008 | 11:03 PM
cooper173's Avatar
i was thinking more toward the distributor. how do i find out if the fuel pressure regulator is good or bad?
Old Mar 19, 2008 | 11:09 PM
rjsasaoka's Avatar
From About.com:
An easy way to test for an FPR leak in the vacuum side is to replace the vacuum line going into the FPR with a length of clear tubing. Now you'll be able to see leak as it happens. IT will most likely show failure when your vacuum is at its lowest point, as in during acceleration.
That is what I was able to find searching the net.
Old Mar 19, 2008 | 11:13 PM
The only problem with it being the distributer is why would it cut out after a few seconds and then not start at all. I doesn't sound like distributer symptoms. Hold on, see if you can wiggle your distributer.
Old Mar 19, 2008 | 11:16 PM
cooper173's Avatar
it doesnt move at all.
Old Mar 19, 2008 | 11:32 PM
I wish I could help you, I really can do too much more over the internet....Sorry[sm=wtf.gif]
